FORGER
    Image texture resolution
    General Discussion
    • S
      silly-grocery last edited by
      Hello, i am a new user of forger. I look for hours but i can’t find a way to chage the size/resolution of the texture image of an obj, by default it is set to 2048*2048. Is there any way to change it on the app or an alternativ app ( without using a pc !!! )? Thake you.
        Hi silly-grocery,
        The painting in Forger is based on Vertex paint. It doesn't use any texture file internally for this.
        The texture export is then file-based, and after checking with the Forger team (hence the delay based on the weekend), this is not changeable inside the application.
        However, if you save it as a Cinema 4D file, the Vertex Colors are stored in a Vertex Tag. This means that all the data you have provided in Forger is available.
        The texture can be baked to a higher resolution depending on the Mesh density.
        Senior Trainer, Maxon Master Trainer
