FORGER
    Problem selecting edges
    General Discussion
    edge selection model
    • O
      Oliver last edited by Dr. Sassi
      hello
      I've been using Forger for a couple of weeks and I've encountered the same problem several times: when I select an edge and then try to select more edges, all the edges of the face are selected instead of just the edge I clicked on.
      Is there any solution?
      thank you!
        Hi Oliver,
        I can't reproduce this here.
        Have you checked the Selection options (tap on the selection icon) to see any changes with different settings?
        Please check with the tech support
        My best wishes
          This post is deleted!
          • O
            hello!
            thanks for your answer. Yes, I have tried the different options of the selection tool but the problem does not solve. When trying to add a second edge to the selection, all the edges of the face are added...
            Regards!
              Sorry to hear that, Oliver,
              I hope the tech support will be able to locate the source of the problem.
              • O
                Thanks Sassi!
                • O
                  I have noticed that if I use the transform tool to select edges instead of the selection tool, the selection works correctly.
                    It is very nice of you to update the thread, Oliver.
                    Thank you very much! I'm glad it is working for you!
                    Enjoy!
                    • S
                      steak-national last edited by steak-national
