FORGER
    How to make shortcut of fav tool.
    General Discussion
    on screen icon shortcut customize
    • Gravi
      Gravi last edited by Dr. Sassi
      How to make shortcut dissolve tool on screen.
      ![alt text](IMG_0264.jpeg image url)
        Hi check-feel,
        To my knowledge, having the Dissolve in the icon menu is not an option.
        If you need this often, it makes sense to have it there.
        Please share this with Maxon, "Share Your Ideas":
        My best wishes
        Senior Trainer, Maxon Master Trainer
        Gravi 1 Reply Last reply Reply Quote 0
        • Gravi
          Gravi @Dr. Sassi last edited by
          @Dr-Sassi thnx for reply, and last question is
          Dissolve tool is merge tool
          Like 2 faces into 1
            You're welcome, check-feel,
            The Dissolve tool, simply said, does not merge; it typically takes away definitions in a certain area of the model. Merging, from my point of view, would be more about creating a connection between or among polygons while not reducing the details.
            The typical result of the Dissolve in Forger is an N-Gon, which has some advantages during modeling, but anything after modeling might produce questionable results. Typically, the mesh is triangulated inside the render engine, which might not be how it is preferred. N-Gons are polygons with more than four points to define the boundary edges. If two polygons are dissolved in an N-Gon, the amount of boundary (island) points does not change.
            (Many three or 4-point polygons in a group are not an N-Gon.)
            https://help.maxon.net/fgr/en-us/#html/model-actions.html?Highlight=dissolve
            I hope that helps.
