FORGER
    Some recommendations
    General Discussion
    read me
    • F
      Forger Moderator last edited by Dr. Sassi
      Hi and welcome to the Forger Forum!
      Here you'll find some recommendations for a proper functioning of the forum:
      -Be kind and respectful:
      Treat others the same way you would like to be treated. "Hello" and "Thank you" are always more than welcome here.
      If someone doesn't confirm that their problem is solved, their post will be marked as solved within fifteen days, even if is not.
      -Be patient:
      Read other posts before opening a new one. Sometimes you will not be the only one with the same question/doubt/problem. If there's no answer, please don't create a new post with the same query, just be patient or contact directly with support.
      -Be clear and concise:
      In order to avoid misunderstanding, try to be specific and brief. If you provide examples, this will help your "helpers".
      -You should also know:
      This forum is a place to ask questions about Forger and how to use it, if you have technical issues you should contact support.
      Enjoy and keep creating!
