FORGER
    Exporting to Cinema 4d
    General Discussion
    • C
      chemical-database last edited by
      I am having issues connecting forger to Cinema 4d for exports and imports. I went through the steps I saw on the site but I still can't get it to work
        Hi chemical-database,
        Sorry about your trouble.
        You just tell me it is not working, which gives me very little to work with.
        There are a few steps, and each has a result. When do you not get the expected result, which would perhaps help to get it working? Please let me know.
        https://help.maxon.net/fgr/2024/en-us/#html/fileio.html?TocPath=_____6
        Such information should also be detailed if you contact the tech support
        If the trouble you encounter is not a workflow but based on technical problems, like hardware or software code). Here, I can guide you as much as possible through the steps.
        I used the current releases and the same WiFi (same "band" and frequency)
        In Cinema 4D, I have set up the Preferences> Extension> Forger File Transfer.
        I restarted both apps after set up, and I was able to round-trip my model. I hope we get this done for you as well.
        One question: can you airdrop files? (I presume an iPad to Mac workflow)
        Senior Trainer, Maxon Master Trainer
